My POE seems to have stopped working on my Lennar home after a recent power outage.
telnet@ICX7150-C12 Switch(config-if-e1000-1/1/1)#show version
UNIT 1: compiled on Aug 8 2023 at 22:55:03 labeled as SPS08095m
(31457280 bytes) from Primary SPS08095m.bin (UFI)
SW: Version 08.0.95mT211
Compressed Primary Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compiled on Tue Nov 29 12:43:26 2022
HW: Stackable ICX7150-C12-POE
Serial #:FEK3803S09T
Current License: 2X1G
telnet@ICX7150-C12 Switch(config-if-e1000-1/1/1)#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 124000 mWatts.
Power Allocations: Requests Honored 0 times
1/1/1 On Off 0 0 n/a n/a 0 n/a
1/1/2 On Off 0 0 n/a n/a 0 n/a
1/1/3 On Off 0 0 n/a n/a 0 n/a
1/1/4 On Off 0 0 n/a n/a 0 n/a
1/1/5 On Off 0 0 n/a n/a 0 n/a
1/1/6 On Off 0 0 n/a n/a 0 n/a
1/1/7 On Off 0 0 n/a n/a 0 n/a
1/1/8 On Off 0 0 n/a n/a 0 n/a
1/1/9 On Off 0 0 n/a n/a 0 n/a
1/1/10 On Off 0 0 n/a n/a 0 n/a
1/1/11 On Off 0 0 n/a n/a 0 n/a
1/1/12 On Off 0 0 n/a n/a 0 n/a
Total 0 0
--More--, next page: Space, next line: Return key, quit: Control-c^C
Total 0 0
I have enabled and disabled the ports repeatedly and the switch otherwise seems to be working fine. Any ideas?
