I have several Ruckus access points that i use for APoaS surveys. When setting these up for a survey I must manually set the transmit power on both bands. I have a R550 that is set up correctly and working fine. However when i try to set the transmit power settings on my H550 or my T350c it does not change. I go to the transmit power setting and set it to for example -6dB and then select Update settings and it does not set and reverts back to -1dB and will not change. Any ideas?
