I have the Lennar Home Ruckus ICX7150 with 2 R320 APs. The firmware on my swichc and APS is up-to-date. Since I want to have more reliable WiFi in my home office, I really only need the whole system to connect to two laptops. My internet provider is AT&T Fiber 1G.
Even though my master AP is much closer to my office than my ATT router, I actually have faster download/upload speeds on the router WiFi (and close to 1000 mgb/s when using an ethernet cable from my Ruckus to my laptops), but when I connect to my ruckus AP (with no other clients connected), the speed is worse than the ATT router WiFi signal.
Are there any settings that I can use to optimize the AP or WiFi settings on unleashed (the mobile app doesn't work on my iPhone, and I connect directly using the Ruckus IP) -- should I make it only 5 Hz, and then change the other settings or ....
Again I only want to optimize the system for speed for one or two devices (laptops). I am ok with not using it for anything else, I just cant have my Zoom meetings interrupted any longer.
Thank you
