My Ruckus R510 has no power. I have reset the other Ruckus device as I have seen in other post but no change. I have green and amber lights on the one Ruckus device.
Hi @scoobydoo
Greetings of the day,
Thanks for the detailed description of the issue,
As per the description, the switch has green and amber lights on it, which means that the switch is stuck in boot mode. Also if the factory reset process doesn't work I would request you to try performing the software recovery process.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/m-p/47483
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-using-a-USB-flash-drive/td-p/46781
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
