my ruckus acces point not work
Hi
As per the case description, I understand that your RUCKUS setup is not working.
Please let me know the answers to the below queries to assist you better.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
