Considering the use of the access point's internal antenna (no use of external antennas). What is the maximum Wi-Fi range?The internal antenna has 120° direction, is this horizontally? What is the vertical range?
AP Ruckus T750SE
Per the documentation : Extended 30-degree vertical beamwidth.
https://support.ruckuswireless.com/documents/3496-ruckus-t750se-ap-quick-setup-guide-qsg
