Ive tried restoring the bak file and it wont do anything. The AP is connected to a router and it is unable to get an internet connection. Unit seems defective and shows up as lifetime warranty on the site.
Hi @thejammer
As per the case description, I understand that one of your RUCKUS Access Points is not working.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
1. Yes it worked but recently it started having odd issues. No there was power outage, i simply did a reboot because of performance issues.
2. Power is flashing, ctl/2.4g and 5g are all solid green.
3. Internet is working fine when connecting directly to modem
4. Single access point
It wont let me upload a pic even when logged in
It should allow to upload the Pictures when logged in. If still its not allowing you upload the pictures, please use the below link to upload them.
https://drive.google.com/drive/folders/1vJZC6HkGGb8O4pg-rXI46Bz4S2VCL4PC
I dont have this specific switch
Have you connected the RUCKUS Access Point directly to the Internet Service Provider's (ISP) Router?
Please confirm.
Thank you again.
Yes, tried that as well. Same outcome
Please confirm how it was connected when it worked before?
Thank you.
