I’m having a similar problem this post:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/ICX-7150-C12P-displays-orange-light-for-SYST-indicator/m-p/50305/page/2
When I got to the ping step in PuTTY it says “ARP Retry count exceeded; starting again; ping failed; host 192.068.0.2 is not alive“
Hi @AM15
Greetings of the day,
For further troubleshooting steps please share the image of the switch and the access points as mentioned below.
Also please let us know before performing software recovery process have tried factory resetting the switch or not.
Hi Jayavidhya-
I did try the factory reset, as you can see from the picture below, the lights are now flashing orange (but the power light is still solid green). Prior to the reset, the power light was solid green and the SYST light was solid orange.
Thanks!
Thanks for your response,
Based on the images you have shared it seems like the ethernet cable coming from the router/access points has been wrongly connected to the switch.
Please make sure the cable is actually connected to the ICX-7150-C12P ( Switch ) In one of the 12 ports in the middle.
Also please check whether the cable is in good condition so that both ends and connectors look good.
Hello.
the Ethernet cord that goes to the access points is in the correct place, you can tell in the picture because it’s the blue one. The yellow one was going to my computer for troubleshooting. Everything is on the same position it has always been. Both ends of the cable look fine.
I have the same error everytime like @AM15.
ARP Retry count exceeded; starting againping failed; host 192.168.0.2 is not aliveICX7150-Boot>
My firewall is off already. Closed Putty and did all the steps all over again and keep getting the "not alive" error
Hi @DiazFranknel
Hope you are doing well
As this case is raised by @AM15 which is now closed.
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
