Hi @Dennis6131
As per the case description, I understand that you need assistance in setting up your RUCKUS devices.
Yes, Internet you can connect any ISP (Internet Service Provider’s) Router OR Modem-Router combo device to the RUCKUS ICX-7150-C12P Switch.
Please note, that if your ISP modem is directly connected to the ICX-7150-C12P Switch, it doesn’t work only with the Modem. The connection must be from a Router or Modem-Router combo device.
Please refer to the short guide link below about how to connect the devices as a reference:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Most-common-Setups-for-Lennar-homes-users/td-p/47106
Thanks, this is very helpful. It is as you said, I must connect the ISP modem + router to the Ruckus.Would you happen to know if there is a RUCKUS APP so I can rename the SSN of the R510 APs?
You can manage your RUCKUS Switch and R510 Access Points using using the Master AP IP Address OR https://unleashed.ruckuswireless.com/
Even you can download the RUCKUS Unleashed application on your smartphone to manage the same. (Please refer to the below video)
https://www.youtube.com/watch?v=O9XciALyuYU
