My ruckus system is not powering up, it flashes the lights for a second then nothing. This is a ICS7150. I have already tried multiple attempts to reboot the device but nothing seems to be working. Please help me resolve this.
Hi @dang7602
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not booting up after a power outage.
Could you please try to reset the Switch as explained in the below VIDEO:
As you mentioned that you tried reset, once again we will try to reset the Switch as described below:
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please check and let me know.
Followed the above and it still does not work properly. What do I do now?
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and a VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
It's uploaded, video (20231220_132133) and a photo (20231220_132432)
Apologies, I cannot open the VIDEO you uploaded. Could you please record one more and upload the same?
It was re-posted.
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
