I am having issues with my Ruckus ICX7150-C12P. It appears it is completely dead. When I plug the power cord back on, the lights blinks once and then it shuts off. Is there any warranty I’m eligible for on my Ruckus ICX7150-C12P? Thanks!
Hi @T_nguyen916
As per the case description, I understand that your RUCKUS setup is not working, with the RUCKUS ICX-7150-C12P Switch has no power.
Please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a Working power outlet. Please refer to the below pictures as an example.
I uploaded the pictures and video per your recommendations. Please let me know if I need to do anything else and what are the next steps moving forward. Thank you for your assistance!
Greetings of the day!!!
Thank you for sharing the requested PICTURES and VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Did I answer your query? If yes, hit the Kudos buttons and also accept the answers as Accepted solutions.
