Please help, I'm desperate and at my wits end, I've spent hours trying to get this switch reconnected after a power outage but I can't figure out what to do.
I tried to follow instructions from other posts but it didn't work.
I downloaded PuTTY but every time I tried to use the IP address with SSH or Telnet like in the video I get the following error - Network error: Connection timed out.
I scanned the switch IP and used the address but it still didn't work.
I tried going into the unleashed dashboard and editing the IP address to match what was found on the scanner but now it's telling me a new error which is - Failed to ping ICX Suggest checking network so I don't know if I made the problem worse.
How do I reach the Command prompts and fix this, I work from home and rely on this.
I can access the IP address directly by typing it in but once I'm there I have no idea what to do or how to change anything.
