I'm facing a problem and cant figure out how to solv.
When the clients are redirected to user_login_auth.jsp we receive a error: err_empty_response
Any help?
Hi @agon1982 I believe this is a browser specific, could you please confirm if you are seeing this on all the browser?Also please check on different clients.I have seen some cases where an addon pluggin on the browser caused this, I also recommend you to upgrade the controller if it is running on older version.
This is, really, a problem with the chrome browser ( including Android mini browser to captive portal authentication).
I get the same error (no addons or extensions) when I try to authenticate to the Zonedirector web management console using google chrome (no problem with firefox or safari)
Zonedirector 3000 with 10.1.2.0 build 318
Hi @agon1982 Can you try upgrading the ZD 3000 to 10.2.1.0.236. That is the last version for ZD3000.
Hello, sanday_kumar!
I have about 220 APs R300 + 50 APs R310 that are not supported anymore in 10.2
