How can I Monitor CPU usage, I am using PRTG, I can Monitor network bandwidth and device uptime, But I cant get CPU usage, Access point is R510
Hi @soulcage57,
Please confirm if AP is in standalone mode or you are managing it using a controller.
Also confirm the controller/AP software version.
I have 10 APs, one of them is master and I am managing Network from there.
You still did not confirm the product info and software versions.
Since you mentioned "master" I am assuming it is Unleashed.
As per the SNMP guide for 200.14, system CPU utilization is supported.
https://docs.commscope.com/bundle/unleashed-200.14-snmpref/page/GUID-01089E44-D7B1-45E3-B28B-1343640F6952.html
Hi @soulcage57 The exact OID would be as belowruckusUnleashedSystemStatsCPUUtil.1.3.6.1.4.1.25053.1.15.1.1.1.15.13.0You can fetch the subtree of this OID to find the list of connected APs to Master.
