I just lost my WIFI access this morning. My main WIFI source (through AT&T) is working fine, but lost my Unleashed/Ruckus access. I don't even know where to start troubleshooting.
Hi @gonzales09
As per the case description, I understand that Wi-Fi from your RUCKUS devices is not working.
1. If it worked before, was there any power outage before you started facing this issue?
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
Thanks for reaching out. I finally got it to come back online. I am still not sure what happened, but it is back up and running now.
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
