We have ZoneDirector 1200 with 8 APs, we have enabled SNMP v3 on ZD and want to monitor devices on the Nagios monitoring system so we need plugins to import in Nagios, from where we can find plugins.
Hi @waseem81pk,
From ZD side you just need to configure SNMP agent. MIB files are available in support portal, if you can confirm the current firmware version, we can share the link.
However, plugin for Nagios is not something we provide. It is flat configuration on ZD, just configure SNMP agent and make sure SNMP - ZD can talk to each other.
Hi Syamantak, kindly check the below-mentioned firmware version and share the related MIB files link.
Model: ZD1200Licensed APs: 25S/N: 352138000649Version: 10.5.1.0 build 240
Please use below link to download 10.5.1 SNMP MIB files.
https://support.ruckuswireless.com/software_terms_and_conditions/3284-zonedirector-10-5-1-0-124-ga-snmp-mibs-zip
