My RUCKUS APs are keep going offline frequently, it used to work pretty well but since past 1 month I am having this issue. It is causing instability to my home network, please advise me the next steps.
Thanks,
Chandu.
Here are the notifications from Unleashed.
Hi @chandugutti1987
Hope you are doing well!!!
As per the case description, I understand that your Unleashes app receives Heartbeat Loss errors frequently.
1. If it worked before, was there any power outage before you started facing this issue?
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
Hello Imran, thank you for your response.
1. I am not aware of any power outage at my home.
2. Yes, in regular working conditions I see lights on the switch ports, but when the AP goes offline it will be really hard to go and grab the status of the LEDs from switch immediately. By the time I go and check, AP might have come back online.
3. Yes, I am using ATT Fiber link and it is pretty reliable.
4. I have 2 APs connected to this switch. all Lights are Green in working condition. But, when AP goes offline I see all the lights in OFF state.
Right now, I have the switch and APs in working condition. So, it is hard to take the picture of APs and switch when the network is offline. Is there a better way to pull the logs from AP and switch to troubleshoot this issue?
I would suggest you create a new WLAN/Wi-Fi SSID and create a separate 5G or 2.4G network from your Unleashed Access Point to avoid any Wireless interference between them causing the ‘Heartbeat Loss’ errors. Please refer to the below link and screenshot. Please refer to the below links to create and new WLAN/SSID.
Creating a New Wireless WLAN (SSID):
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Creating-a-New-Wireless-WLAN-SSID/td-p/47049
Video:
https://www.youtube.com/watch?v=eSl_8rs1QnU
Please observe once you create a new SSID and let me know if you have any queries in this regard.
