Perhaps from a power outage, the APs have lost power and internet from Ruckus switch. Doorbell (ring) dead.
Can I RMA! This is the 4th time this season there is an outage. Please help asap as Doorbell and Security camera outage.
Hi @Karupasu
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, after a power outage.
Please note, that this issue may happen frequently when your RUCKUS ICX-7150-C12P Switch is on an old version, and it requires an upgrade to avoid this issue in the future. And I will assist you with the upgrade after getting some information.
And we apologize, we cannot RMA without trying troubleshooting steps.
Could you please let us know the answers to the below query to assist you better?
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Please let us know the answers to above query or let us know if you have any queries in this regard.
Just sent. Here it is again.
I appreciate the quick response Imran!
I see from a previous case of yours multiple reset/reboots resolved this issue with Switch reverting back to its normal state. Could you please try the same so that I can assist you with upgrading the Switch to a new stable version to avoid this issue in the future?
As I can see from the picture you shared, there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
As you mentioned that you tried resetting, once again we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
