Hello! I have two Smart zone 104 controllers, they are in the same cluster. I needed to reset the first controller to factory settings, I turned off the controller, pressed the F/D button and turned it on, at first the status indicator flashed red, but after 10 seconds it started flashing green, after that the link on the port disappeared and is still flashing. I tried to connect via the console, when booting I was given that CentOS 7 was booting, after booting it asks me for localhost login, I tried all logins, but none came up. What should I do? So far, everything is working on the second Smartozne controller
