-I’m in a Lennar home Canopy Grove Escondido, CA. -cant access the switch since power outage.
-ICX 7150-C12P with 2 wireless access points. -no power or lights on both access points.
restart of power didn’t change anything.
Hi @BlowBoatTech
Greetings of the day,
Please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
https://docs.commscope.com/bundle/unleashed-200.12-onlinehelp/page/GUID-19D4261B-D10B-4DE3-B63A-3498F80103D0.html
RUCKUS LED lights
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-973C8AE8-837A-41C7-9811-BAEF6ADEF3D3.html
Also please share the image of the switch and the access points showing the LED status and the cable connections.
no lights are showing on both of the AP’s.
Also, the switch will not allow pass through of data to any hardline Ethernet connections. I cannot log into the switch either.
To provide further troubleshooting steps please let us know the LED status of the access points using the below guide.
EVERY light on both AP’s are out. It’s blank. Nothing is lit up.
Thanks for the response.
Based on your description your switch has one green and one yellow light, it means that the switch is stuck in boot mode.
Status lights have been flashing for 10 minutes after I released the reset button.
still no lights on AP’s
If the resetting process doesn't work, we need to perform a software recovery.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/m-p/47483
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-using-a-USB-flash-drive/td-p/46781
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
Quick guide? First off your software only cover Mac OS from 2016! Who has a computer running an OS that old? I tried it and it was a waste of my time. I just finished downloading the programs for a PC but it seems my cable isn’t compatible. I tried using a USB to USB-C data transfer cable is already had. I’m guessing I have to go buy a dedicated USB to USB-C cable for this to communicate?
