My device is powering up anymore and has not lights on either. I have tried multiple power cables and power cycled the device and router as well. Online forums suggest to reset it with a pin have not worked either.
Hi @Pinderhayer
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS ICX-7150-C12P Switch is not powering up.
As you mentioned that you tried reset, once again we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
Hi Imran - thank you for this recommendation. I tried over 20 times and am still having no luck with my Ruckus system getting back online. Even my access points seem to have lost power / connection.
any further help would be greatly appreciated.
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
Hi Imran,
thank you. I’ve uploaded a photo and video. Please let me know if you need anything else.
thanks! jay
Hi @Jgadani
As this case is raised by @Pinderhayer
To avoid confusion with posts, you can create your own post with the above description.
Hello Imran, I know it has been a while since you sent this solution - right now I was about to take those pictures and upload them. As I plugged the Ruckus in it lit up, however despite being powered up and plugged into the ISP it is not providing a connection to any devices connected to it. Could you help me out with this?
Hi @Pinderhayer Greetings!!!
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
Kind regards,
Sofia Gätjens
Yes everything was working before than one day it just lost power and everything along with it. There was no outage around the time the ruckus stopped working.
there are two access points - there are no lights on these either.
the ISP works well and consistently. plugged in - outlet is working (lit up green) unit has no. power
access point 1ap 2
