I have (2) APs in the house that are not receiving power. I have tried to factory reset the switch but seems to be getting stuck trying to reset and lights will continue to blink 10+ min.
Hi @tpatte15
Greetings of the day,
Please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
https://docs.commscope.com/bundle/unleashed-200.12-onlinehelp/page/GUID-19D4261B-D10B-4DE3-B63A-3498F80103D0.html
RUCKUS LED lights
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-973C8AE8-837A-41C7-9811-BAEF6ADEF3D3.html
no lights on the AP's
on the switch the power light is green (16) and the SYST is yellow/amber (7) when i push the port status mode selection button(1) no lights will recact in the status box.
Based on your description your switch has one green and one yellow light, it means that the switch is stuck in boot mode.
Thanks Jayavidhya,
I tried the factory reset last night after reading previous posts and once i relased the reset button the light jsut continued to flash well past a typical reboot time (10+ min)
Thanks for the response.
If the resetting process doesn't work, we need to perform a software recovery.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/m-p/47483
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-using-a-USB-flash-drive/td-p/46781
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
