I am having an issue.. This is brand new, I have configured it now 4 times and each time it always has the same issue. I am starting to think this is a hardware issue, or that it is just not going to work in our network. I have a Ruckus 1200 with ZoneDirector. The issue is that;
Once configured I can't authenticate into the WAP's, I get an error that indicates Authentication Error. If I set the WAPS to no password, open authentication, the same issue occurs.
Eventually the AP's that are connected (4 of them) will loose connection to the Zone Director and they won't connect at all, The DHCP on our network is setup for the client connections, but the AP's and the Zone Director use a static IP address, However the AP's don't ever get that address, They also eventually commit suicide and require me to get up on a ladder and hard reset them. Once they are reset the loop continues, where I am going through the same issues over and over again.
I can find them though on the network, and can remote into them, but the DHCP listed in the AP is not what I am using to connect to them.. The DHCP will show 192.168.0.1 as the address, but on my network they are in a different subnet, and it is what I am able to connect to.. I also can't find the 0.1 which shows on the interface as existing anywhere..
It was more simple to configure a Cisco PIX on a 12,000 Person network, with 300 VLans than it has been to configure this boat anchor.. Beyond pissed at this thing.. It's been 7 days of nightmare.
