ZoneDirector
Issues with ZD1100 post 9.7 upgrade (Map view, rogue AP's)
In addition to issues with Guest Pass after my upgrade to 9.7, I've found that "Map View" no longer works with Chrome or IE. It just sits at a type of loading page.
I've also found that I wasn't alerted to a rouge AP until 4 hours after it was turned on (by me). I don't know if this is a new issue/concern or if it's always been this way. In the past it seemed like after a few minutes I would be alerted, but I never tested this myself.
Curious if anyone else is having these same problems?
keith_redfield
The Map View issue is likely related to Java version installed on your PC. Check if there's an upgrade available. If you're already running the latest...we may have a problem and so please open a support case.
