Ruckus ICX 7150-C12P switch stopped working. SYST light amber, PWR light green. Consoled in to switch and tried to reset. Getting: "ERROR: can't get kernel image!"
ICX7150-Boot>reset
resetting ...
Next boot is from primary
verify_uboot_uimage: Cmd sf probe 0:0
Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size device 0 offset 0x0, size 0xc0000
SF: 786432 bytes @ 0x0 Read: OK
using GPIO[7] to reset
Ruckus Wireless Bootloader: 10.1.15T225 (Jan 30 2019 - 23:08:47 -0800)
Booted from partition 1
DRAM: Validate Shmoo parameters stored in flash ..... OK
Logging is Enabled...
UBOOT: BE Mode
ICX7150-12 (POE), PVT1
SYS CPLD VER: 0x4 Released Ver: 0xa
Writing Shmoo values into flash .....
SF: Detected MX25L6405D with page size Unlocking L2 Cache ...Done
Net: Registering BCM xgs eth
Broadcom XGS Iproc Ethernet driver 0.1
Using GMAC0
gmac_mac_init: Chip ID: 0xb160
r = 0x0, addr = 0x1, devad = 0xffffffff, phy_id = 0x600d84aa
Add phy reset delay
Add phy reset delay
Basic ethernet functionality initialized
bcm_xgs_gmac-0 [PRIME] ETH MAC: 34:20:e3:31:bb:25
SF: Detected MX25L6405D with page size Flash set to SECONDARY FL
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size done
Valid environment: 2
SF: Detected MX25L6405D with page size device 0 offset 0xbfe00, size 0x200
SF: 512 bytes @ 0xbfe00 Read: OK
SF: Detected MX25L6405D with page size Access set to PRIMARY FL..
SF: Detected MX25L6405D with page size Erasing SPI flash...Writing to SPI flash...Flash set to SECONDARY FL
Valid environment: 1
Booted From: Uboot partition 1
bootdelay: ===
Booting image from Primary
NAND read: device 0 offset 0x0, size 0x2000000
7 ecc_errors after reading 1b48000:1b49800
iproc_nand_read_page returned 2
NAND read from offset 0 failed -22
0 bytes read: ERROR
## Loading kernel from FIT Image at 70000200 ...
Bad FIT kernel image format!
could not boot from primary, no valid image; trying to boot from secondary
BOOTING image from Secondary
NAND read: device 0 offset 0x4000000, size 0x2000000
1 ecc_errors after reading 5b48000:5b49000
NAND read from offset 4000000 failed -22
0 bytes read: ERROR
ICX7150-Boot>ERROR: can't get kernel image!
