I have 2 R510 AP's. Both are stuck on a red PWR light no matter what I do. I have tried resetting it and am getting no results. Any help would be appreciated.
Hi @Cpaquette86
Greetings of the day,
For detailed understanding of the issue please let us know the LED status of your switch.
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on?
Also please let us know whether you have access to the unleashed dashboard or Ruckus application?
Syst and PWR lights are green on the switch. When I push the status button all are green except for USB and it's amber.
Please unplug and plug the Access Points ethernet cables from the Switch panel and reboot your Switch (disconnect and connect the switch from the power outlet). Once the Switch boots up, please check the Access Points.
Please make sure ethernet cables from Access Points, any devices and your ISP (Internet Service Provider) Router should be plugged into any of the 12 ports as shown in the below screenshot.
OK. I did this and there is still no change, still solid red on the AP PWR.
