Wireless Questions and Best Practices
External Antenna for 7762-S-AC outdoor
Hi All,
I need to setup 2 ruckus 7762-S-AC as using zonedirector as a backbone within 2 sites. Since the unit has 2 connectors for the antenna,Is it possible for me to use 1 antenna only using either vertical or horizontal polarity? Is there any settings in zonedirector need to be change if it's possible. thanks
Comments
There are no comments yet
Firmware Recommendation
SmartZone
