I need immediate help My internet does not work and I need someone from Ruckus to call me to get this fixed. I have to work in the morning and do not have INTERNET!!!!!!!!
Is your ISP up?
Everything green just no internet connection
Hi @Scipe11
As discussed on your other post.
If you are unable to get the IP Address of the Switch, we must try getting console Access to the Switch as described below.
If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case, we need a USB type C to USB standard or Console cable Rj45 to USB.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
