Hello Community,
I have recently moved from a Lennar home to another builder. I brought my ruckus system with me. Is it possible for it to work in the new home? Also, if so how do I set the device up?
Thank you!
admin test
Hi @Gaberod0007
Hope you are doing well!!!
As per the case description, I could understand that you need assistance in setting up RUCKUS devices.
Please refer to the short guide link below about how to connect the devices:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Most-common-Setups-for-Lennar-homes-users/td-p/47106
what does this mean?
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the cable connections to the Switch ports)
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
