Hi all,
We have an EOL ZD 3000 running 9.13.3.0 build 164, and a dozens of R500 and R600 access points. We need to have better resilience now that we don't want to wait for a network redesign that's coming. So, for the interim, we'd like to get all the R500 and R600 to Unleashed ... at least to the versions that have Wave 1 support. At a later date, we'll look at whether they need to go to modern APs.
With that all in mind, some of the APs are in very hard to get to locations (e.g., high up) -- and as in production units during extended working hours, the windows to update are limited -- and we need to do something that's lower risk of failure, as losing all for a day would be painful. Bottom line: these APs, located in two cities, but sharing one ZD3000, make resets and local loads are real pain to do.
It looks like there might be a path that we can update the APs, via the ZD. But, it looks like they are on 10.1 ZD versions or later. We don't have a support agreement for the ZD (and it seems a waste given that we want to retire it), so we can't get to more than 9.3.3 right now.
Is there a way to update the R500s and R600s without physically reseting them? Can we do that via ZD 9.3.3.164? Or if not that, is there a way to update them singly or in bulk from the command line when the access points are currently associated with the ZD3000?
Thanks in advance! Neil
