- Certain 802.11ac WLAN cards will not be above to connect / view the SSID being broadcasted from a 802.11ax AP. This is due to a known issue on the card driver.
- Affected WIFI cards:
Intel® Wireless-AC 9560
Intel® Wireless-AC 9462
Intel® Wireless-AC 9461
Intel® Wireless-AC 9260
Intel® Dual Band Wireless-AC 8265
Intel® Dual Band Wireless-AC 8260
Intel® Dual Band Wireless-AC 3168
Intel® Wireless 7265 Family (Rev.D)
Intel® Dual Band Wireless-AC 3165
Intel® Wireless 7265 Family (Rev.C)
Intel® Wireless 7260 Family
Intel® Dual Band Wireless-AC 3160
- The work around to test if this is the issue you are facing is to disable 802.11ax on the WLAN interfaces of the AP. The Following commands can be used to disable 802.11ax on the AP.
# set mode wifi0 11ng
# set mode wifi1 11ac
- If the client is able to connect after executing the above commands then, please upgrade the client driver to the following versions:
Driver versions for Windows 10
| Supported Adapters |
| 20.70.0.5 and newer | Intel® Wireless-AC 9560 Intel® Wireless-AC 9462 Intel® Wireless-AC 9461 Intel® Wireless-AC 9260 Intel® Dual Band Wireless-AC 8265 Intel® Dual Band Wireless-AC 8260 |
| 19.51.14.1 and newer | Intel® Dual Band Wireless-AC 3168 Intel® Wireless 7265 Family (Rev.D) Intel® Dual Band Wireless-AC 3165 |
| 18.33.13.4 and newer1 | Intel® Wireless 7265 Family (Rev.C) Intel® Wireless 7260 Family Intel® Dual Band Wireless-AC 3160 |
- Turn the radios back to 802.11ax mode by using the following commands after the driver upgrade.
# set mode wifi0 11ahe
# set mode wifi1 11ghe
Reference: https://www.intel.com/content/www/us/en/support/articles/000054799/wireless.html
