I just had a power outage a few days ago and i called my internet provider and they let me know that it was the ruckus therefore i need help fixing the issues please
Hi @Chanteal_84
Greetings of the day,
Please provide the detailed description of the issue.
1:Are the Access points getting power?
2:If the Access Points are getting power, can you connect to the SSID/Wi-Fi ID?
3:Is the SSID/Wi-Fi ID from the Access Point is slow, but the AT&T work fine?
4: Please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
https://docs.commscope.com/bundle/unleashed-200.12-onlinehelp/page/GUID-19D4261B-D10B-4DE3-B63A-3498F80103D0.html
RUCKUS LED lights
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-973C8AE8-837A-41C7-9811-BAEF6ADEF3D3.html
Yes, the one upstairs is working fine but the one downstairs is not working.
No, I can’t because from my understanding there is a short and this is the second time this happened.
My xfinity internet is working fine. Its the second access point down stairs thats the issues therefore the Xfinity Tech had to unplug it.
downstairs
Upstairs
Based on the images you have shared, your ICX-7150-C12P Switch has steady green on SYS and the PWR which means the lights are in a normal state.
It seems that your PoE devices are not working connected to the ICX-7150-C12P Switch.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
To check this, first, we have to get access to the switch, and there are Two ways to get access to the switch.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-find-my-Ruckus-Devices-IP-address-using-free-applications/m-p/47027#M7
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-ICX-7150-12P-or-access-points-quot/m-p/47388
ICX7150-C12 Router>
Show version
Show inline power
Show inline power detail
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
I followed the steps and it is still not working.
