We recently had a power outage and my Ruckus switch and 3 APs do not power on or have any green or orange lights. I used different outlets, used a pin for the reset button, sang it a song and still nothing. What are my next steps?
I replaced the power cord with a new one, and again there are no lights or power going to the switch. Is there anything besides, disconnecting the.l cord several times, resetting several times and using a new power cord that I can do? What’s the next step now?
Hi @Wpookis
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged into a power outlet there is no power to the Switch. Also, you tried to reset the Switch. And you confirm that the Switch is plugged into a well-known outlet/power source also tried with different cords. However, the failure persists. This unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Hope you are doing well!!!
From the case description, I could understand that your RUCKUS ICX-7150-C12P Switch and Access Points are not powering up after a power outage.
First, we will try to reset the Switch as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES AS DESCRIBED ABOVE.
Thank you for the reply. I’ve reset multiple times and it is still dead. No lights, no power. What’s the next step?
Could you please try to check by replacing another Power cord with the Switch? In case the current power cord has been damaged.
