Hi, I have an ICX 7150 C12P. My power went out last night and the box itself has an amber light for SYST and a green light for PWR. I’ve tried resetting but I can’t get the AP’s to connect. Any help is much appreciated.
Hi @gladyspaulette
Greetings of the day,
Based on your description, if the switch has one green and one yellow light, it means that the switch is stuck in boot mode.
If the resetting process doesn't work, we need to perform a software recovery.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/m-p/47483
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-using-a-USB-flash-drive/td-p/46781
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
I attempted the steps provided on multiple occasions and it has not resolved the problem. Could someone please contact me directly to trouble shoot OR for new access points to be mailed. This is starting to really impact my ability to work from home and I need to resolve it soon.
Warm regards,
Gladys
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email.
We will be exclusively supporting customers via this community forum support model.
Please let us know whether you have tried performing software recovery process or not.
Also if you find difficulties in following the steps please share the screenshot of the error you are getting while following the steps.
