Similar to other posts, I get a flash when plugged in, then nothing. I have tried other cables as suggested in other posts, but the unit is unresponsive. Looks like a replacement situation.
Hi @Jj1271 Could you please confirm if this is a Lennar home setup?If yes, I can redirect this to our dedicated Lennar support for further assistance.
Yes, it is a Lennar home setup. Thanks!
Thank you for the confirmation, let me involve our dedicated tech support for Lennar homes.
Hi @Jj1271
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and the unit is not powering up.
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same)
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights. Also, light the status of Access Points.
Please let us know the answers to the above queries or if you have any queries in this regard.
The system came with our house in 2018. It was set up and has been working since. This was our first problem.
There are no lights on on the router at all. When you first plug the unit in, all of the lights flash green one time, then all go dark. No activity after that.
We have two access points, and there are no lights on either of them.
I am at work and cannot send pictures at the moment. I hope this helps.
Please try to reset the Switch once as described below:
https://docs.commscope.com/bundle/icx7150-installguide/page/GUID-D3B5DB74-53A7-4F8D-82F9-6EB600879EE7.html
Also, please share the requested pictures at your convenience.
