Yesterday, there was power trip for 5 mins after that all access points light are not coming and it's not working. I did switch off for modem and swich for 10 mins and try it again but still light are not coming for access points.
Hi @viplavse
Thank you for the response and sharing the requested information.
Based on the troubleshooting done, you confirmed, and we saw that after the reset, booting up the Switch, and after trying the software recovery process multiple times, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again and we appreciate your patience.
Lennar Home Community.
I did reset as well but after resetting all orange lights are keep blinking. Still it's not working.
Hi Viplavse,
Please login to the AP using through GUI by default user name is super and the default password is sp-admin
Please check the below article for login.
https://support.ruckuswireless.com/articles/000001538
Please check the internet link status
Are you able to view any default SSID from the AP ?
Please try to configure the WLAN as the requirement.
May i know the firmware version of the AP ?
Please check and let us know the above queries to assist you to resolve the issue.
Sunil Acharya
Hi Sunil_Acharya,
After resetting the switch, it keeps blinking all amber lights. I tried to connect with my PC with a network cable but it's showing automatic DHCP configured. So how to set the Ip address for the switch, I tried Ip scanner as well but the switch IP address is not showing over there.
Hi @viplavse When you connect the Laptop to the Switch, are you getting an IP?If not, probably the APs are also not getting the IP if they are DHCP set.The APs will roll back to the default IP address (192.168.0.1) when they are not receiving the IP from DHCP.Remove all the APs from Switch >> Connect only 1 AP >> Connect the Laptop to the Switch >> Make sure the Laptop is on same range of AP's (Like 192.168.0.10) >> See if you can ping 192.168.0.1.If you can ping, then SSH to it and then set the IP using the below commandset ipaddr wan <IP address> <Subnet Mask> <Gateway>
