Yes this is a Lennar setup
HI @Ladyk1016 We have a dedicated support for Lennar homes, let me route to the thread to the correct team for further support on this.
Hi @Ladyk1016
Hope you are doing well!!!
Thank you for the information you shared,
From the case description, I can understand that your RUCKUS setup is not powering up.
Could you please let us know?
2. May I know on which device you are unable to see the lights powering up Ex: Switch or Access Points? (Please share the pictures of the same)
Switch:
Access Point:
3. Also please Make sure it is plugged into a well-known outlet/power source.
4. How many Access Points are connected to the Switch?
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights. Also, light the status of Access Points.
Please help us with the above queries to assist you further. Or let us know if you have any queries in this regard.
Lennar Home Community.
