I checked the switch which only has two lights on, Syst -- orange, pwr -- green. please help.
Hi @PQ
Greetings of the day,
Based on your description, if the switch has one green and one yellow light, it means that the switch is stuck in boot mode.
Please follow the below steps to solve the issue.
1-Try to disconnect from the Power outlet the ICX- 7150 and reconnect it.
2-Try to press the reset button using a paper click or a small stick
If the resetting process doesn't work, we need to perform a software recovery.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-recovery-on-an-ICX7150-switch/m-p/47483
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-using-a-USB-flash-drive/td-p/46781
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-7150-C12P-via-TFTP/m-p/47187
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-an-Upgrade-via-Web-GUI-ICX7150-Switch/td-p/48200
Thanks, it resolved by resetting the system.
Great!!
Good to hear. Thanks for letting us know.
