I have a dead switch that came with my Lennar home. How to get it replaced? I have swapped cables and outlet, no go.
Hi @shobeav
Hope you are doing well!
1-On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on?
2-Make sure it is plugged into a well-known outlet/power source to discard any issue with the power outlet.
3- Are the Access Points R510 powering up?
4- Are you having any connectivity issues like webpage not loading or slow connectivity.
Once you confirm this let us know you can also send us a photo/picture
