My Ruckus will not power on and when plugged in it flashes an amber light and then goes dark. I'm requesting RMA.
Hi mfg
Hope you are doing well!!!
Thank you for the information you shared,
As per the case description, I could understand that your RUCKUS ICX-7150-C12P Switch does not power ON and when plugged in it flashes an amber light and then goes dark.
Could you please let me know from when you are facing this issue?
Also, Could you please confirm if the Switch is plugged into a well-known outlet/power source?
Lennar Home Community.
This has been happening for a week. The switch has been plugged into a usable outlet and the surge protector always.
Greetings of the day!!!
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering ON and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Your system states that the serial number doesn't exist for this device. The picture shows the serial number of FEK3249N16S. What do I do?
