I have a TP-Link router with a Motorola MB8611 modem and it seems like there have been constant issues with connectivity. What’s the best combo with this Lennar Ruckus setup?
Hi @Finnejo
This combination will not be a problem, now you can test where you are having a problem, for example cable a computer to the TP-Link router and then run a speed test, then do the same with the ICX 7150 Swith, so you can check if the problem is the TP-Link router or the switch, or even finally test the wireless connection, so you can confirm whether the problem is the TP-Link router, ICX7150 or the wireless environment, after isolating what is the source you can share the results here, and we can give you more troubleshooting steps.
Yarenis Hernández
