How to remote capture AP packet on smartzone with CLI
Hello @liman,
If you are using FTP to download the pcap then you can follow below syntax from SZ CLI.
vSZ# remote ap-cli <AP_MAC>"set capture eth0 local"vSZ# remote ap-cli <AP_MAC> "set capture eth0 idle"vSZ# remote ap-cli <AP_MAC> "get capture copy ftp <desthost> <destfile> <username> <password>"
Let me know if this helps.
Parik
Hi @liman,
We can execute remote AP cli command and run AP compatible commands.
In below example captures can be streamed to Wireshark from AP.
vSZ# remote ap-cli AA:BB:CC:0A:0B:0C "set capture wlan0 stream"Packet capture on wlan100OK
how to capture with local mode and get the saved pcap files
That feature is currently available only on GUI. Other than HTTPS, there are no other means to download the PCAP.
I can capture packet on ap and get the pcap file with ftp. just want to know how to do it on smartzone with cli
