I tried to do factory reset the modem, but now the power light is continuously blinking, the other lights are off how can I fix this?
Hi @Xrene34,
If power LED is flashing green, this means AP is looking for a routable IP address from the network.
Check if AP is connected to a network which has a DHCP server, if not, you have to configure AP's IP address manually by accessing it over it's default IP address.
