Hi, is it possible to use the H510 PoE out if I power the AP via a DC adapter and not via a PoE switch?
Thanks for the help
Hi @Digger_321
Hope you are doing well
I hope this can be useful for you
H510 Power Options and Available Power Out for PoE Out and USB
H510 Power Source Power Available for PoE Out and USB
Note: The LAN1+PoE port is intended for PoE-powered peripheral devices such as IP telephones.
Link: https://support.ruckuswireless.com/documents/1789-ruckus-wireless-h510-quick-setup-guide
Best Regards
Fernando Vasquez
Exactly the info I needed. Thank you, I have probably overlooked in the manual.
No problem at all ! @Digger_321
At any time, you are welcome
