I have a lot of R550's getting powers from different manufacturer switches but they all seem to have the same warning about not getting enough power. These are running the current firmware -R550_200.12.10.105.129. According to the website they only require 802.3at PoE+ Max power consumption PoE+ : 18.71W. I currently have the AP plugged into a switch with a 240 watt power supply for 8 ports. The specs on it are minimum of 19.39 W per port. I only have 2 ports plugged in on the switch. I have another conneted to a 30watt poe injector. They both have the same indicator -
According to Netgears website the 8 ports are PoE+
802.3at
Ports.
My POE injector is rated at 30w - is there a typo on the website for the R550? Do they a require 60watts?
