We have a R710 Access point and I need to know if this type of configuration is possible.
The R710 has two ethernet ports, one with PoE (eth1) and a second port (eth2).
The WLAN is on a guest VLAN to provide Internet access to guests outside our department.
Is it possible to put the eth2 port in the same VLAN as the WLAN?
In a unique situation, we are trying to connect a desktop to the Guest network. However, the eth2 port shows that it's on the employee side!!!
Sherwood
