i have one R650 AP, managed by vSZ. i have found the TX Power Adjustment & Auto channel selection configuration.
What interests me is R650 supports Smart Antenna configuration?
i can't find any Smart Antenna configure in my vSZ.
Hi Edison,
I assume you are referring to BeamFlex+ technology? The R650 certainly has this feature - see on the data sheet: https://www.commscope.com/product-type/enterprise-networking/wireless-access-points/indoor/r650/
Please note, BeamFlex+ is not a user configurable feature and is chip-based firmware-controlled hardware.
I hope that helps,Darrel.
hi Darrel, thank for replying.
BW, i have a question, how can i know the positive effection that brings by BeamFlex+.
can i do some comparative test to prove it?
The R650 access point (AP) with the latest Wi-Fi 6 (802.11 ax) technology delivers increased capacity, improved coverage and performance in dense environments. The R650 is our mid-range dual-band, dual-concurrent AP that supports six spatial streams (4x4:4 in 5GHz, 2x2:2 in 2.4GHz). The R650 supports peak data rates of up to 2974 Mbps and efficiently manages up to 512 clients connections. Furthermore, 2.5GbE Ethernet ensures the backhaul will not be a bottleneck for full use of available Wi-Fi capacity. vidmate.app saveinsta
