When I power the AP R650, I can not search the wifi —— Configure.Me-XXXXXX, and the 2.4G and 5G LED are both down.
When I setup the AP following the guide (https://docs.commscope.com/bundle/Unleashed-R650-QSG-800-72625-001-RevA/resource/Unleashed-R650-QSG-800-72625-001-RevA.pdf), I can not search my wifi which is set before, and the 2.4G and 5G LED are both down.
After I login the web page by using the IP, the Access Point shows there is a AP which is "Disconnected", and the AP in the list is "Not support", it makes me confused! By the way, the software version of my AP is 200.8.10.3.278.
How can I make it work? Please give some solution to me, thanks very much.
