Hello all,
our Zonedirector 1200 model device is freezing. Unable to access console and web interface. Restarting the device fixes the problem, but after a few hours it freezes again. The status and power lights on the device are solid green. The power adapter was changed but the problem is not solved. Have you encountered such a problem? And did you find the solution?
Thanks in advance,
Regards
Onur.
