Guide on changing IP and subnet of Smartzone 100 along with APs on existing network
Hi, I am planning to cutover an existing network whereby I have to change the IP and subnet of the current SZ 100 and APs. Basically from 172.x.x.x/20 to 192.168.x.x/24.
DHCP will be from an external source and supplied to the APs.
Any guide of how I may go about with this?
Hi Ivan,
I assume all the APs are set to DHCP, please take a backup of both configuration and cluster backup, then please run AP CLI script on SZ100 to let all the APs know the new SZ100 IP address ( this is an extra step to make sure that all APs connect back to SZ quickly ).
Now go-ahead and change the IP address of SZ100, please wait few minutes as because certain services would restart; after a while SZ100' GUI should be back APs would show up.
There isn't any document specifically for this, but these should be sufficient, should there be any please keep this thread updated.
Abilash PR.
Thanks Abilash.
Yes, all APs will be set to DHCP fo this change. Currently, their IP addresses are statically assigned.
May I know the actual command of the IP address change for the AP CLI script?
You mentioned that it will take a few minutes as certain services would restart, for this process, do we need to reboot each APs too?
Cheers,
Ivan
Hi Ivan,
Please save the below as .txt file and apply it on the AP Zone.
fw_version=3.1.1.0.349 ( change this with your AP firmware version )
model=all
set scg ip xx.xx.xx.xx ( change this with you IP 192.168.x.x/24 )
No, the don't need to be rebooted.
Abilash PR.
Hi Ivan,
Please refer below link on how to apply the script.
http://docs.ruckuswireless.com/smartz...
Abilash PR.
Hi Abilash,
Could you provide the command to enable the dhcp for the APs on the script?
Hi Ivan,
The AP CLI script to change the APs to fetch IP from DHCP server is below.
model=all
set ipaddr wan dynamic
reboot.
Please be cautious when using this, when doing this you have to make sure that AP show connected on the controller else it would fail.
Let me know how it goes.
Thank you,
-Abilash PR.
